w1lluser1's avatar
w1lluser1
Compatibility of RBK853 wifi 6 system with RBS20 satellite
Hi there,
Is it possible to use an RBS20 satellite with the RBK853 wifi 6 system? I could either wire the RBS20 satellite to the RBR853 router or have it wireless, however I do not want to disable AX wifi-6 mode on the RBR853 router.
Any help is appreciated!
Cheers.
  • FURRYe38's avatar
    You could wired the RBS to the RBR. Currently RBS AC series units are not wirelessly compatible with Orbi AX.
    • w1lluser1's avatar
      w1lluser1
      Hi Furrye38,
      Thanks for the response. Can I just confirm that I would not need to disable AX mode for the RBK850 system, it will only be the RBS20 satellite that will use AC technology?
      Cheers!
      • FURRYe38's avatar
        You can leave AX mode enabled. The RBS20 will be acting like a wired AP is all.
