Wilocat
May 25, 2025Tutor
Conection problem
I’m using an RBK850 with two satellites. The issue I’m encountering is that I have a Google TV streamer in the living room and a Google Chromecast in the bedroom. The Chromecast repeatedly loses it...
May 26, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What WiFi channel configurations are currently set on the router?
Armor, Smart Parental Controls or Circle, IPv6, Traffic Meter.
- WilocatMay 29, 2025Tutor
test
