Wilocat
May 25, 2025Tutor
Conection problem
I’m using an RBK850 with two satellites. The issue I’m encountering is that I have a Google TV streamer in the living room and a Google Chromecast in the bedroom. The Chromecast repeatedly loses it...
Wilocat
May 29, 2025Tutor
Since last week i have the latest firmware updated automatically. The firmware version is V7.2.15_5.1.16
The fiber modem was also replaced by my provider last week; it's a Sagemcom pack mailto:F@ST 5684 deu to a takeover, and they upgraded from 1 Gb to 2 Gb.
This was connected by the provider itself.
The entire house is wired with Cat 7, including the switch cables and everything going throug LAN.
My house is 120 m2 , and is made of concrete.
The distance to the sattelites is about 5 to 6 meters.
The wan WAN preference is: Internet Port (2.5 Gbps).
The channel is: 2.4 GHz autochannel and the 5 GHz channel 36.
Armor, Smart Parental, IPv6, and the trafic meter were turned of.
The disconection was only WAN and occured only with the Google Chromekast every 3 to 4 seconds.
Following the suggestion, I turned off all the sattelites, then everything went back to normal. Later added the sattelites one by one, and everything is working correctly now
