dona13
Jul 14, 2026Aspirant
Connect iot devices
Hello. I would like to know how to make my iot device (LaCrosse weather station) connect to the iot network that I have set up in my RBR850 router ? The device is already connected to the wifi but no...
- Jul 14, 2026
Be sure the RBR has updated FW that has this feature in it. Any FW prior to v7.x does not.
dona13
Jul 15, 2026Aspirant
CA81199
Jul 15, 2026Guru - Experienced User
dona13 wrote:CA81199
Ok, so this:
- https://www.lacrossetechnology.com/products/ca81199
https://cdn.shopify.com/s/files/1/0035/7443/1790/files/ca81199_english_and_french_manual_031919.pdf
https://cdn.shopify.com/s/files/1/0035/7443/1790/files/ca81199_faqs.pdf
Looks like you have to use their app to change the wifi connection - the guides don't give details.
- dona13Jul 15, 2026Aspirant
Yes and it also looks like I must uninstall the app, or at least delete the account and everything and start over, there is no easy way to just switch the network. The Lacrosse app is not so friendly, things you can do are not obvious.
Thank you for serching and helping, nice day.
