JohnScorn
Apr 08, 2022Follower
Connect wifi extender to Orbi AX4200
I have an Orbi AX4200/CBK752. I have ADT Pulse system with wireless cameras. The further camera from the Orbi router frequently goes offline. ADT recommends Netgear wifi extender model WN3000RP. Can these older extenders be added to Orbi? Ironically, the camera that goes offline is only 10' from the Orbi satellite but it won't connect to the satellite.
Yes. Should work ok. Something to try.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many? - Thompson649Aspirant
JohnScorn wrote:I have an Orbi AX4200/CBK752. I have ADT Pulse system with wireless cameras. The further camera from the Orbi router frequently goes offline. ADT recommends Netgear wifi extender model WN3000RP. Can these older extenders be added to Orbi? Ironically, the camera that goes offline is only 10' from the Orbi satellite but it won't connect to the satellite.
Check this manual out may be help you https://www.downloads.netgear.com/files/GDC/RBK752/RBK752_UM_EN.pdfVW Credit
