Denise71
Jul 25, 2025Initiate
Connecting RBR750 router cables to New Modem C4000BZ?
I received a New Century Link Modem (C4000BZ) but tech won't install my router (RBR750). I'm not connecting to the ORBI. Does anyone know how to connect the cables.
I strongly believe someone had hacked into my orbi too!
- Denise71Initiate
Wow, I was amazed by your response, thank you. I've got some homework to do, :-). Again, thank you very, very much!
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
New: https://community.netgear.com/kb/en-orbi-knowledge-sharing/static-ip-address-configuration-for-ap-mode/2456256
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...Any connection on the RBR with ISP services needs to use the Yellow WAN port in back of the RBR connected to the ISP service modem.
Review this as well:
Orbi MESH Troubleshooting, Suggestions and Tips | NETGEAR Communities
