spepet
Feb 24, 2022Aspirant
Connection issues with Microsoft Teams
Since I moved to ORBI WIFI 6 2 weeks ago. I have problems with my Microsoft Teams connection. Every couple of minutes the connection is interrupted for just a couple of seconds.
Operation mode: Router
Firmware Version: V4.6.3.16_2.0.51
DHCP: On
Laptop: DELL XPS 15 9500
OS: Windows 11 Pro fully updated
Does anybody have an idea what could help?
Thanks
Let us know what works...
Netgear has set up a community forum specifically for the Orbi AX products. Most of the people who watch that forum are more likely to have experience with Orbi AX (WiFi6 RBK 3,7,8 and 9 Series) products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you. - FURRYe38Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?How is the PC connected to the system? Wired or wireless?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡- spepetAspirant
Actual firmware is:
- ORBI router RBR850: V4.6.3.16_2.0.51
- ORBI satellites (2): V4.6.3.16_2.0.51
Internet Service Provider Modem the Orbi router is connect to:
- Model#: TG3492LG-LC
- MFR: did not find the information
Connected PC to ORBI Wifi showing issue:
Model: Dell XPS 15 9500
Connection type: wireless
Home situation:
- Size: 1250 Sq Ft
- Distance from RBS850 satellite 1 to RBS850 satellite 2: 20 ft
- Distance from RBR850 router to RBS850 satellite 2: 40 ft
First I had only RBS850 satellite 1 connecte to RBR850 router with Backhaul status POOR. Then I added RBS850 satellite 2 and RBS850 satellite 1 connected to RBS850 satellite 2 with both Backhaul stauts GOOD.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
