doug007
May 13, 2022Tutor
Connection Refused to 192.168.1.1
All of a sudden I'm getting a "can't connect" from the Orbi app to my RBR850.
I also get a "Connection Refused" when trying to connect to 192.168.1.1 on my local network. I double-checked, that is the router address.
WiFi still works. My two satellites seem to be up and running, I've tried rebooting the router. No change. I've tried plugging directly into the router via ethernet, Still "connection refused". It seems like the management service failed to start? Gotta be a software issue of some sort.
Any ideas? I'm about ready to try the factory reset and reconfigure everything but that will be a pain in the butt and I want to avoid it.
Unfortunately, support expired so I can't create a case.
Anybody have any ideas. before I nuke it?
- doug007Tutor
Never mind. I finally found the big thread about this issue. Botched firmware update. Factory reset the only way apparently
- SnarglefargInitiate
Thanks. I was having the same problem and this thread saved me time finding a solution.
