TanujB's avatar
TanujB
Tutor
Oct 27, 2020
Constant speedtest in web client
(My router model is Orbi RBR850 / AX6000 - menu won't let me pick that)
I am seeing "constant" speed when I do speedtest in the webclient under Advanced > QoS. Firmware V3.2.16.6_1.4.4. Always the same 491.37Mbps download. I am connected to the 2.5gbps port, have a 1gbps speed limit and often see higher speeds than this on hardwired devices with ookla.
Anyone else seeing this? Super strange and likely a bug in the new firmware?
  • Same for me.  The speed test has loads a test last run in July of 2020.  The speed test in the mobile app fails as well.
  • FURRYe38's avatar
    What browser are you using?
    Does the speed results show differently if you use a wired PC and Ooklas isntallable speed test app on the PC?
