chertarte
May 13, 2026Aspirant
Customer Support
This is the only format besides spewing on social media or sending an actual letter to the corporate office in San Jose that I can think to use. 1 of 3 Orbi's not working, all bought at same ti...
chertarte
Thank you for your response:
Yes, Orbi Satellite RBS850
It is powering up. They have tested it syncing, it is not syncing either wireless or direct ether connect. Also did a 60 second factory reset and a 30 sec on/30 off/30 on again, neither of these worked. Also deleted the device in the router and still did not work. Keeps showing ‘disconnected’.
I’m not tech savvy at all….so hopefully describing this all correctly.
May 14, 2026Guru - Experienced User
What firmware version is on the RBR?
Had the RBS been synced to the RBR before?
Has the system been firmware updated recently?
If you factory reset both RBR and RBS and setup from scratch, and did the 30-30-30 reset on one RBS, possible the one RBS is just faulty.
Can you get by with the other two RBS?
How big is the home in sq feet?
chertarte wrote:Yes, Orbi Satellite RBS850
