DougOr
Feb 20, 2026Aspirant
DHCP issues after reboot
I have the same problem with one sattelite, 40 devices, AT&T Fiber BGW320 for 4 months (prior was Cox cable) . Using an AI as a tutor its helped me move from V 7.2 7 15 , to V 7.2 8 5 on both router ...
Feb 20, 2026Guru - Experienced User
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Does this happen with the RBS turned OFF?
What channel configurations are currently set on the router? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Is IPv6 enabled on the RBR?
Using ISP detected DNS on the RBR or custom DNS? Try custom like Cloudfare or Quad9
Try the Orbi system in AP mode?
Static IP Address Configuration for AP Mode | NETGEAR Communities
Disable IP pass thru on the ISP router if you try this.
