DougOr
Feb 20, 2026Aspirant
DHCP issues after reboot
I have the same problem with one sattelite, 40 devices, AT&T Fiber BGW320 for 4 months (prior was Cox cable) . Using an AI as a tutor its helped me move from V 7.2 7 15 , to V 7.2 8 5 on both router ...
Apr 30, 2026Guru - Experienced User
Any progess on this?
DougOr wrote:I have the same problem with one sattelite, 40 devices, AT&T Fiber BGW320 for 4 months (prior was Cox cable) . Using an AI as a tutor its helped me move from V 7.2 7 15 , to V 7.2 8 5 on both router and satellite disable WIFI on ATT Gateway, IP Passthru , factory reset twice, when I manually put in the ip address for my LAN 10.0 0 40 and gateway 8.8.8 8 it works great on my TV again, BUT I have to do IP Configuration manually. the stove, and fridge connect with the Samsung Hub, but no IOT cameras work. Alexa started working, no plugs or bulbs will work anymore. I'm to the point of Downgrading the firmware which I have read to use
V 4.6 14 3, or even Alternate "Rock Solid" Choice: V 3.2 16 6 . what do you suggest?
