jasonhavens
Jan 05, 2021Aspirant
Disable SSDI broadcast on Orbi CBR750
There is no way to disable the SSDI broadcast on the brand new CBR750 (firmware V3.2.16.9_1.4.7). Is it possible that Netgear moved the setting from Advanced > Setup > Wireless Setup (Wireless Settin...
Jan 05, 2021Guru - Experienced User
No, seems the NG doesn't support that on Orbi AX model systems. Same with Orbi RBK7 and 8 series.
