andrayxz
May 25, 2021Aspirant
Disastrous RBR750 ping spikes - help please
Recently bought RBR750 Orbi (WiFi 6 Router AX4200) mesh with two satelites. Coverage and speeds are great but having massive ping spikes (up to 1500ms) every 10-20 seconds which are making my online...
May 25, 2021Guru - Experienced User
"- Distance between router and 1st satellite: 16ft" 16 feet is too close. 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
- andrayxzMay 25, 2021Aspirant
Router and 1st satellite are connected via cable, this should not have an impact imo.
- FURRYe38May 26, 2021Guru - Experienced User
Regardless of connection of the RBS, distance is too close.
Is the RBS directly connected to the back of the RBR or is there a switch in between?
What is the quality of the LAN cable used between the RBR? CAT#?- andrayxzMay 28, 2021Aspirant
Yes, RBS is directly connected to RBR. The cable used is Cat5E.
