Validus
Mar 24, 2022Luminary
DNS Error Popup Issues (Round 2)
Using the NETGEAR Orbi RBK852 AX6000 mesh router, since purchased, with various firmware versions
(no other routers I've used in the past have this problem)
Now currently on Firmware Version v4.6.7.13 Official Release.
Even this version of Firmware gives me the DNS issues. Popping up for a split second.
This time the message is "ERR_NAME_NOT_RESOLVED".
(Different from the previous versions of Firmware)
It will occur randomly and only the first time visiting a webpage. You will have to clear out cache for it to reoccur. Even then it's rare to happen again.
However, for each webpage it does it on, I have noticed under the console log > network it will have a Status = (failed) net::ERR_NAME_NOT_RESOLVED on one of the scripts or something the webpage is trying to load upon it.
I've tracked the reason to this being blocked in my HOSTS file, such as:
0.0.0.0 ssl.google-analytics.com
Mentioned at the top of the big list is:
# This list is Copyright 2000-2017 Safer-Networking Ltd.
So I've figured out it's from the app called SpyBot by Safer-Networking. After using it's Immunization tool to block out advertising trackers, etc. It sets them all to point to the IP Address 0.0.0.0
If I visit any of them directly I will get that message "ERR_NAME_NOT_RESOLVED" and it will remain there.
Other routers tend to ignore this and skip over it. However, since I've had the Orbi it's been throwing out those DNS warnings over the entire webpage and then refresh to load the page as normal a few seconds afterwards.
Is this something I can fix on my end, because I just find it annoying and it appears to slightly slow it down as well? Otherwise is it an issue with the way the Orbi router handles the IP Address 0.0.0.0?
Possible fix:
NAT Filtering > SIP ALG
NAT Filtering is set to Secure and has a tick box to disable SIP ALG upon it checked by default. Unticking that and enabling SIP ALG appears to of improve it's performance, creating a snapper response to device calls and may have of resolved my DNS issue too.
Will mark this as resolved, once fully tested and confirmed.
What is the CAT# cable between the modem and RBR?
What all devices do you have connected to the RBR?
What browsers are you using?
Do you have any Armor or SPC or had any of these two features enabled recently?
Is IPv6 enabled or disabled?
I presume you have have already done a factory reset and setup from scratch after v.13 was loaded?
"I've tracked the reason to this being blocked in my HOSTS file, such as:
0.0.0.0 ssl.google-analytics.com" < is this listed in your host file? What happens if you put a (#) in front of this entry on the host file?
- ValidusLuminary
ONT = Chorus Optical Network Terminal Model Type 200
It doesn't have Wifi features or any setup options I can access. It appears to have it's own flat cable of a CAT 5E type, I've used that to connect directly to the Orbi Router. Set as Router Mode.
The Orbi Router then has a CAT 6 cable directly to a desktop PC. Only that device is connected to the main router.
Other Satellites connected to the TV, Nvidia Shield Pro and other various devices will use CAT 5e Patched ethernet cables.
I have Armor and SPC both disabled. UPnP is also disabled.
I have VLAN enabled and VLAN tag group set ID = 10 on all Wired Ports and Wireless. This is required by the ISP.
I use IPv4. IPv6 is disabled as my ISP doesn't support it. I did previously use a 6to4 Tunnel for IPv6 and that solved the DNS issues from appearing, however Google Search Engine warned it was insecure and being discontinued. So gone back to IPv4. Hense why I bring it up again (Round 2).
I have Armor and SPC both disabled. UPnP is also disabled. Would you enable uPnP please let see if this changes anything. After enableing this, do a full power OFF of the ISP ONT and RBR for 1 minute then back ON.
Wondering if this maybe a factor here as I don't use this for my ISP and I have not seen any DNS issues whatsoever. Possible that mis-handling between the RBR, this vlan configuration and the ISP ONT could be at play here.
I use IPv4. IPv6 is disabled as my ISP doesn't support it. I did previously use a 6to4 Tunnel for IPv6 and that solved the DNS issues from appearing, however Google Search Engine warned it was insecure and being discontinued. So gone back to IPv4. Hense why I bring it up again (Round 2). After testing with uPnP enable and if you don't see any change, please re-enable this as a short term test to see if this problem continues or is resolved by using 6to4 DNS configuration.
Lets see if any of these two items change the DNS behavior. I believe that probably that your ISPs VLAN configuration and how the RBR is handling it maybe the problem as you say, this has been happening on every FW versions, this leads me to think that something in this configuration is not working right. We may need you to capture debug logs for NG review.
When entries in the computer hosts file (I am not aware that Orbi routers maintain a hosts file) point to 0.0.0.0, that means "don't go there".
It is the computer making this decision, not the router. Open a command window on the computer and attempt to ping 0.0.0.0. It will fail.
- ValidusLuminary
It's around 95% fixed but still happens rarely on certain websites. I believe when accessing scripts or redirects cross domains?
I tend to get a couple shown as...
Connection: StalledThe website will then show the entire page with the message "ERR_NAME_NOT_RESOLVED" and then reload it to display the webpage fine.
Only occurs on first time loading the DNS, not once it's cached. I think it's cross-domain only as well, such as a subdomain loading files from the main domain name?
Here's an example if helpful. Using Windows 11 with Microsoft Edge.
Visit the search engine: https://www.google.co.nz/
Searching for "intel ark 12th gen cpus" (without the quotes)
URL clicked upon: https://ark.intel.com/content/www/us/en/ark/products/series/217837/12th-generation-intel-core-i7-processors.html
Console errors
commons-page.min.js:35 Access to XMLHttpRequest at 'https://signin.intel.com/?TYPE=33554433&REALMOID=06-1a08b802-d9f5-4485-975b-3f5f70265129&GUID=&SMAUTHREASON=0&METHOD=HEAD&SMAGENTNAME=9IyroXSoMF7kVVITXzYzIESBjH6eFkyv3kC3z6rcWCrL6oJOa3iddh8NL5Fe3ago&TARGET=$SM$https%3a%2f%2fsfederation%2eintel%2ecom%2ffederation%2fstatus%2easp' (redirected from 'https://sfederation.intel.com/federation/status.asp') from origin 'https://ark.intel.com' has been blocked by CORS policy: The value of the 'Access-Control-Allow-Origin' header in the response must not be the wildcard '*' when the request's credentials mode is 'include'. The credentials mode of requests initiated by the XMLHttpRequest is controlled by the withCredentials attribute. XMLHttpRequest.send @ commons-page.min.js:35 (anonymous) @ 12th-generation-intel-core-i7-processors.html:757 commons-page.min.js:35 HEAD https://signin.intel.com/?TYPE=33554433&REALMOID=06-1a08b802-d9f5-4485-975b-3f5f70265129&GUID=&SMAUTHREASON=0&METHOD=HEAD&SMAGENTNAME=9IyroXSoMF7kVVITXzYzIESBjH6eFkyv3kC3z6rcWCrL6oJOa3iddh8NL5Fe3ago&TARGET=$SM$https%3a%2f%2fsfederation%2eintel%2ecom%2ffederation%2fstatus%2easp net::ERR_FAILED 302 XMLHttpRequest.send @ commons-page.min.js:35 (anonymous) @ 12th-generation-intel-core-i7-processors.html:757 commons-page.min.js:31 CSRF data not available;The data may be unavailable by design, such as during non-authenticated requests: SyntaxError: Unexpected token < in JSON at position 0 d @ commons-page.min.js:31 c.onreadystatechange @ commons-page.min.js:32 XMLHttpRequest.send (async) XMLHttpRequest.send @ commons-page.min.js:35 e @ commons-page.min.js:32 (anonymous) @ commons-page.min.js:36 (anonymous) @ commons-page.min.js:31 (anonymous) @ commons-page.min.js:31 commons-page.min.js:35 GET https://dpm.demdex.net/id?d_visid_ver=4.4.0&d_fieldgroup=MC&d_rtbd=json&d_ver=2&d_orgid=AD2A1C8B53308E600A490D4D%40AdobeOrg&d_nsid=3&ts=1651630385123 net::ERR_BLOCKED_BY_CLIENT XMLHttpRequest.send @ commons-page.min.js:35 fireCORS @ utag.js:1011 g._loadData @ utag.js:1011 g._getRemoteField @ utag.js:1011 g.getMarketingCloudVisitorID @ utag.js:1011 g.<computed> @ utag.js:1011 (anonymous) @ utag.js:1011 g.init @ utag.js:1011 Xe.getInstance @ utag.js:1011 loadExperienceCloud @ utag.js:1121 u.send @ utag.js:1166 LOAD @ utag.js:918 WQ @ utag.js:883 (anonymous) @ utag.js:1008 setTimeout (async) EV @ utag.js:922 utag.loader.INIT @ utag.js:1008 utag.loader.PINIT @ utag.js:1006 (anonymous) @ utag.js:1009 commons-page.min.js:35 GET https://dpm.demdex.net/id?d_visid_ver=4.4.0&d_fieldgroup=AAM&d_rtbd=json&d_ver=2&d_orgid=AD2A1C8B53308E600A490D4D%40AdobeOrg&d_nsid=3&d_mid=08276305904252774731436730752552288115&ts=1651630385138 net::ERR_BLOCKED_BY_CLIENT XMLHttpRequest.send @ commons-page.min.js:35 fireCORS @ utag.js:1011 g._loadData @ utag.js:1011 g._getRemoteField @ utag.js:1011 g.getAudienceManagerLocationHint @ utag.js:1011 g.<computed> @ utag.js:1011 (anonymous) @ utag.js:1011 g._callCallback @ utag.js:1011 g._callAllCallbacks @ utag.js:1011 g._setFields @ utag.js:1011 (anonymous) @ utag.js:1011 handleCORSError @ utag.js:1011 o.onerror @ utag.js:1011 error (async) fireCORS @ utag.js:1011 g._loadData @ utag.js:1011 g._getRemoteField @ utag.js:1011 g.getMarketingCloudVisitorID @ utag.js:1011 g.<computed> @ utag.js:1011 (anonymous) @ utag.js:1011 g.init @ utag.js:1011 Xe.getInstance @ utag.js:1011 loadExperienceCloud @ utag.js:1121 u.send @ utag.js:1166 LOAD @ utag.js:918 WQ @ utag.js:883 (anonymous) @ utag.js:1008 setTimeout (async) EV @ utag.js:922 utag.loader.INIT @ utag.js:1008 utag.loader.PINIT @ utag.js:1006 (anonymous) @ utag.js:1009 utag.js:949 GET https://connect.facebook.net/en_US/fbevents.js net::ERR_BLOCKED_BY_CLIENT loader @ utag.js:949 (anonymous) @ utag.1802.js?utv=ut4.48.202008122020:35 u.send @ utag.1802.js?utv=ut4.48.202008122020:35 LOAD @ utag.js:918 (anonymous) @ utag.1802.js?utv=ut4.48.202008122020:38 (anonymous) @ utag.1802.js?utv=ut4.48.202008122020:38 commons-page.min.js:35 GET https://dpm.demdex.net/id?d_visid_ver=4.4.0&d_fieldgroup=AAM&d_rtbd=json&d_ver=2&d_orgid=AD2A1C8B53308E600A490D4D%40AdobeOrg&d_nsid=3&d_mid=08276305904252774731436730752552288115&ts=1651630385231 net::ERR_BLOCKED_BY_CLIENT XMLHttpRequest.send @ commons-page.min.js:35 fireCORS @ utag.js:1011 g._loadData @ utag.js:1011 g._getRemoteField @ utag.js:1011 g.getAudienceManagerLocationHint @ utag.js:1011 g.<computed> @ utag.js:1011 (anonymous) @ utag.js:1011 z @ utag.js:1011 g.getVisitorValues @ utag.js:1011 AppMeasurement.a.pb @ utag.js:1112 AppMeasurement.a.isReadyToTrack @ utag.js:1112 AppMeasurement.a.p @ utag.js:1112 setInterval (async) AppMeasurement.a.callbackWhenReadyToTrack @ utag.js:1112 AppMeasurement.a.ta @ utag.js:1112 AppMeasurement.a.t.a.track @ utag.js:1112 wap_aa.config_event_map @ utag.js:1107 originalTemplatePieceOfCode @ utag.js:1164 callback @ utag.js:1166 wap_tms.custom.executeCallbackWhen @ utag.js:129 u.send @ utag.js:1166 LOAD @ utag.js:918 WQ @ utag.js:883 (anonymous) @ utag.js:1008 setTimeout (async) EV @ utag.js:922 utag.loader.INIT @ utag.js:1008 utag.loader.PINIT @ utag.js:1006 (anonymous) @ utag.js:1009 12th-generation-intel-core-i7-processors.html:1 Tracking Prevention blocked access to storage for https://lasteventf-tm.everesttech.net/?_les_imsOrgId=AD2A1C8B53308E600A490D4D@AdobeOrg&_les_sdid=43C19EEF2F162850-4D294E741344332A&_les_last_search_click=&_les_rsid=intlcrpglobal&_les_mid=08276305904252774731436730752552288115&_les_url=https%3A%2F%2Fark.intel.com%2Fcontent%2Fwww%2Fus%2Fen%2Fark%2Fproducts%2Fseries%2F217837%2F12th-generation-intel-core-i7-processors.html. commons-page.min.js:35 GET https://dpm.demdex.net/id?d_visid_ver=4.4.0&d_fieldgroup=AAM&d_rtbd=json&d_ver=2&d_orgid=AD2A1C8B53308E600A490D4D%40AdobeOrg&d_nsid=3&d_mid=08276305904252774731436730752552288115&ts=1651630385343 net::ERR_BLOCKED_BY_CLIENT XMLHttpRequest.send @ commons-page.min.js:35 window.XMLHttpRequest.send @ utag.js:378 fireCORS @ utag.js:1011 g._loadData @ utag.js:1011 g._getRemoteField @ utag.js:1011 g.getAudienceManagerBlob @ utag.js:1011 g.<computed> @ utag.js:1011 (anonymous) @ utag.js:1011 z @ utag.js:1011 g.getVisitorValues @ utag.js:1011 (anonymous) @ utag.js:1220 $n @ utag.js:1220 mr @ utag.js:1220 yr @ utag.js:1220 Tr @ utag.js:1220 Nr @ utag.js:1220 Gr @ utag.js:1220 ti @ utag.js:1220 ei @ utag.js:1220 fi @ utag.js:1220 si @ utag.js:1220 wap_tms.target.getAndApplyOffer @ utag.js:1193 (anonymous) @ utag.js:1223 setInterval (async) wap_atjs.getRequest @ utag.js:1223 wap_tms.enableTarget @ utag.js:1252 (anonymous) @ utag.js:1187 wap_tms.amc.setCustomersIDs @ utag.js:1125 (anonymous) @ utag.js:1126 aawap.doPlugins @ utag.js:1122 AppMeasurement.a.Ea @ utag.js:1112 AppMeasurement.a.p @ utag.js:1112 AppMeasurement.a.Cb @ utag.js:1112 (anonymous) @ utag.js:1011 g._callCallback @ utag.js:1011 g._callAllCallbacks @ utag.js:1011 g._setFields @ utag.js:1011 (anonymous) @ utag.js:1011 handleCORSError @ utag.js:1011 o.onerror @ utag.js:1011 error (async) fireCORS @ utag.js:1011 g._loadData @ utag.js:1011 g._getRemoteField @ utag.js:1011 g.getAudienceManagerLocationHint @ utag.js:1011 g.<computed> @ utag.js:1011 (anonymous) @ utag.js:1011 z @ utag.js:1011 g.getVisitorValues @ utag.js:1011 AppMeasurement.a.pb @ utag.js:1112 AppMeasurement.a.isReadyToTrack @ utag.js:1112 AppMeasurement.a.p @ utag.js:1112 setInterval (async) AppMeasurement.a.callbackWhenReadyToTrack @ utag.js:1112 AppMeasurement.a.ta @ utag.js:1112 AppMeasurement.a.t.a.track @ utag.js:1112 wap_aa.config_event_map @ utag.js:1107 originalTemplatePieceOfCode @ utag.js:1164 callback @ utag.js:1166 wap_tms.custom.executeCallbackWhen @ utag.js:129 u.send @ utag.js:1166 LOAD @ utag.js:918 WQ @ utag.js:883 (anonymous) @ utag.js:1008 setTimeout (async) EV @ utag.js:922 utag.loader.INIT @ utag.js:1008 utag.loader.PINIT @ utag.js:1006 (anonymous) @ utag.js:1009 12th-generation-intel-core-i7-processors.html:1 Tracking Prevention blocked access to storage for https://adobedc.demdex.net/ee/v1/interact?configId=91275508-1db0-4970-8581-49bde33298f4&requestId=5371469a-bf2b-4a41-a334-eb6448af27ce. 12th-generation-intel-core-i7-processors.html:1 Tracking Prevention blocked access to storage for https://adobedc.demdex.net/ee/v1/interact?configId=91275508-1db0-4970-8581-49bde33298f4&requestId=5371469a-bf2b-4a41-a334-eb6448af27ce. commons-page.min.js:35 GET https://dpm.demdex.net/id?d_visid_ver=4.4.0&d_fieldgroup=AAM&d_rtbd=json&d_ver=2&d_orgid=AD2A1C8B53308E600A490D4D%40AdobeOrg&d_nsid=3&d_mid=08276305904252774731436730752552288115&ts=1651630402608 net::ERR_BLOCKED_BY_CLIENT XMLHttpRequest.send @ commons-page.min.js:35 window.XMLHttpRequest.send @ utag.js:378 fireCORS @ utag.js:1011 g._loadData @ utag.js:1011 g._getRemoteField @ utag.js:1011 g.getAudienceManagerLocationHint @ utag.js:1011 g.<computed> @ utag.js:1011 (anonymous) @ utag.js:1011 z @ utag.js:1011 g.getVisitorValues @ utag.js:1011 AppMeasurement.a.pb @ utag.js:1112 AppMeasurement.a.isReadyToTrack @ utag.js:1112 AppMeasurement.a.t.a.track @ utag.js:1112 AppMeasurement.a.tl.a.trackLink @ utag.js:1112 wap_tms.events.aa @ utag.js:1100 events_aa @ utag.js:149 (anonymous) @ utag.js:227 worker.onmessage @ utag.2080.js?utv=ut4.48.202204082027:4 commons-page.min.js:31 CSRF data not available;The data may be unavailable by design, such as during non-authenticated requests: SyntaxError: Unexpected token < in JSON at position 0 Request URL: https://signin.intel.com/?TYPE=33554433&REALMOID=06-1a08b802-d9f5-4485-975b-3f5f70265129&GUID=&SMAUTHREASON=0&METHOD=HEAD&SMAGENTNAME=9IyroXSoMF7kVVITXzYzIESBjH6eFkyv3kC3z6rcWCrL6oJOa3iddh8NL5Fe3ago&TARGET=$SM$https%3a%2f%2fsfederation%2eintel%2ecom%2ffederation%2fstatus%2easp Request Method: HEAD Status Code: 302 Referrer Policy: no-referrer-when-downgrade access-control-allow-origin: * cache-control: private content-length: 145 content-type: text/html; charset=utf-8 date: Wed, 04 May 2022 02:12:43 GMT dnt: 1 location: /CustomError?aspxerrorpath=/ set-cookie: BIGipServerfmslogin-https=2886013450.47873.0000; path=/; Httponly; Secure set-cookie: TS011c70e7=01c5f9c67ccc3dac66fbdbda19345ddc88533d6bedd076bd338c1e4add5a92d337bf51e81a25a13b62d236b197d150ee275b89aaff; Path=/ strict-transport-security: max-age=31536000; includeSubDomains vary: Origin x-content-type-options: nosniff x-frame-options: SAMEORIGIN x-node: FM102 x-ua-compatible: IE=Edge x-xss-protection: 1 :authority: signin.intel.com :method: HEAD :path: /?TYPE=33554433&REALMOID=06-1a08b802-d9f5-4485-975b-3f5f70265129&GUID=&SMAUTHREASON=0&METHOD=HEAD&SMAGENTNAME=9IyroXSoMF7kVVITXzYzIESBjH6eFkyv3kC3z6rcWCrL6oJOa3iddh8NL5Fe3ago&TARGET=$SM$https%3a%2f%2fsfederation%2eintel%2ecom%2ffederation%2fstatus%2easp :scheme: https accept: */* accept-encoding: gzip, deflate, br accept-language: en-US,en;q=0.9 cookie: detected_bandwidth=HIGH; src_countrycode=NZ dnt: 1 origin: null referer: https://ark.intel.com/ sec-ch-ua: " Not A;Brand";v="99", "Chromium";v="101", "Microsoft Edge";v="101" sec-ch-ua-mobile: ?0 sec-ch-ua-platform: "Windows" sec-fetch-dest: empty sec-fetch-mode: cors sec-fetch-site: same-site user-agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.41 Safari/537.36 Edg/101.0.1210.32 Request URL: https://dpm.demdex.net/id?d_visid_ver=4.4.0&d_fieldgroup=MC&d_rtbd=json&d_ver=2&d_orgid=AD2A1C8B53308E600A490D4D%40AdobeOrg&d_nsid=3&ts=1651630385123 Referrer Policy: strict-origin-when-cross-origin Provisional headers are shown Content-Type: application/x-www-form-urlencoded DNT: 1 Referer: https://ark.intel.com/ sec-ch-ua: " Not A;Brand";v="99", "Chromium";v="101", "Microsoft Edge";v="101" sec-ch-ua-mobile: ?0 sec-ch-ua-platform: "Windows" User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.41 Safari/537.36 Edg/101.0.1210.32 Request URL: https://dpm.demdex.net/id?d_visid_ver=4.4.0&d_fieldgroup=AAM&d_rtbd=json&d_ver=2&d_orgid=AD2A1C8B53308E600A490D4D%40AdobeOrg&d_nsid=3&d_mid=08276305904252774731436730752552288115&ts=1651630385138 Referrer Policy: strict-origin-when-cross-origin Provisional headers are shown Content-Type: application/x-www-form-urlencoded DNT: 1 Referer: https://ark.intel.com/ sec-ch-ua: " Not A;Brand";v="99", "Chromium";v="101", "Microsoft Edge";v="101" sec-ch-ua-mobile: ?0 sec-ch-ua-platform: "Windows" User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.41 Safari/537.36 Edg/101.0.1210.32 Request URL: https://connect.facebook.net/en_US/fbevents.js Referrer Policy: strict-origin-when-cross-origin Provisional headers are shown DNT: 1 Referer: https://ark.intel.com/ sec-ch-ua: " Not A;Brand";v="99", "Chromium";v="101", "Microsoft Edge";v="101" sec-ch-ua-mobile: ?0 sec-ch-ua-platform: "Windows" User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.41 Safari/537.36 Edg/101.0.1210.32 Request URL: https://dpm.demdex.net/id?d_visid_ver=4.4.0&d_fieldgroup=AAM&d_rtbd=json&d_ver=2&d_orgid=AD2A1C8B53308E600A490D4D%40AdobeOrg&d_nsid=3&d_mid=08276305904252774731436730752552288115&ts=1651630385231 Referrer Policy: strict-origin-when-cross-origin Provisional headers are shown Content-Type: application/x-www-form-urlencoded DNT: 1 Referer: https://ark.intel.com/ sec-ch-ua: " Not A;Brand";v="99", "Chromium";v="101", "Microsoft Edge";v="101" sec-ch-ua-mobile: ?0 sec-ch-ua-platform: "Windows" User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.41 Safari/537.36 Edg/101.0.1210.32If I go directly to these URLs which previously stalled the first time, it loads them fine.
Awesome details. Thank you for this. I'll pass this along to NG.
- ValidusLuminary
Possible fix:
