ssylvan
Dec 03, 2020Guide
DNS_PROBE_FINISHED_NXDOMAIN errors on RBR850
So I've noticed that when I use my Orbi in router mode, I get a lot of DNS_PROBE_FINISHED_NXDOMAIN errors in chrome. The error flashes for a bout a second and then the page loads. This happens a couple of times per day.
This does not happen if I use my ISPs router and set the Orbi to AP mode. So it seems like something is busted related to DNS with the Orbi where it occasionally fails to resolve something but then fixes itself. I've tried using automatic DNS as well as manually setting it to Cloudflare's DNS, but no difference. I've also flushed DNS and rebooted everything on my computer but again no dice (and again, this is not an issue when I let my ISPs router do the actual router stuff and turn the Orbi into an AP).
Anyone have any ideas what this is about? I don't see anything in logs relating to this.
Please post about this over inthe Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-axThank you.
ssylvan wrote:So I've noticed that when I use my Orbi in router mode, I get a lot of DNS_PROBE_FINISHED_NXDOMAIN errors in chrome. The error flashes for a bout a second and then the page loads. This happens a couple of times per day.
I guess you have already looked at suggestions like these:
https://www.hostinger.com/tutorials/fix-dns_probe_finished_nxdomain
- ssylvanGuide
Yes. None of that stuff helps. The issue is 100% isolated to the Orbi itself.
I'm having the same problem. Did you ever figure out a solution?
