CBrown_73
Dec 12, 2023Aspirant
Does anyone have an idea of when NetGear may be releasing the firmware updates?
Does anyone have an idea of when NetGear may be releasing the firmware updates? Seems like it's been a while and with new attacks, daily, seems like NetGear would be releasing a little more frequently.
That's not current FW.
What NG router model do you have?
NG doesn't post or make it known when they are forth coming with new FW updates. They just appear and it's never over night or often. Sometimes it takes months or more to see anything. Then there is the age of said model router as well. Once NG deems these models EoL, NG doesn't put forth any more FW updates unless there is a major security issue.
- CBrown_73Aspirant
I have the Orbi Mesh system (RBRE960), 1 router and 2 satellites.
Ok, just FYI there is a Orbi section for your model system. We'll get you there.
Latest v7 FW was posted just this past Sept:
What FW version is on your system now? Mines running the latest v.21 version of FW. Running fine.
- CBrown_73Aspirant
Logged into the router now and it shows current firmware V6.3.7.10
