rthapa1024
Sep 29, 2022Aspirant
Does LAN aggregation exists in Orbi Mesh router
I am planning to upgrade my router from RAX75 to Orbi Wifi . I know Orbi Wifi have WAN aggregation by looking into documentation but unable to find anything related to LAN aggregation. I would like ...
rthapa1024
Sep 30, 2022Aspirant
Hi FURRYe38 ,
Thanks for reply. when you suggest Orbi 8 series, do you mean RBK8XX?
I was looking into the product data sheet for RBK852, I could only find WAN aggregation but no LAN aggregation (Link for Product documentation). Can you point to documentation where you saw LAN aggregation?
~rthapa1024
Sep 30, 2022Guru - Experienced User
Yes, Sorry bout that. My bad. LAG is only supported on the WAN side of the 7 and 8 series Orbi.
