NKeeJohnson
Sep 24, 2026Follower
Ethernet Backhaul Issues
I live in a 4-story, 8,760 sq. ft. home. The problem I have is that the signal keeps dropping when I hardwire the five (5) satellites to my switches. It drops so often that I cannot even use WiFi on ...
Sep 24, 2026Guru - Experienced User
What FW version is loaded on the Orbi system?
How is the switches connected and how are the RBS connected?
Is the Switches directly behind the RBR then RBS connected to the switches?
What CAT# LAN cable are you using? CAT6A STP is recommended.
How RBS should be ethernet connected to the RBR with a switch in the middle:
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
The 960 series is 2.5Gb LAN port supporting, you might consider checking into a mutli GB non managed switch, something past 1Gb.
What channel configurations are currently set on the router?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
Static IP Address Configuration for AP Mode | NETGEAR Communities
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
