Orbidude's avatar
Jun 01, 2024
FaceTime freezing every now and then
Hello,
I recently inquired in another forum about upgrading from my 850 series (router and 2 satellites) to the 970 series just to have the latest technology. I was advised against it because there aren't many devices yet running on 6E or 7. Therefore, I've decided not to upgrade.
However, I realized I should also ask for assistance with fixing FaceTime, as it occasionally freezes even though a satellite is only 15 feet away.
Any help on this matter would be greatly appreciated.
Thank you!
  • FURRYe38's avatar
    Be sure to disable any MAC Address randomizers on phones and pads while at home:
    https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    How many RBS are deployed?
    What is the distance between the router šŸ“” and satellite(s)šŸ›°ļø? 30 feet or more is recommended in between RBR šŸ“” and RBS šŸ›°ļø to begin with depending upon building materials when wired or wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ā€Œā€ŒšŸ›°
    Does this happen with the RBS turned OFF?
    Does this happen with both wireless and wired devices?
    What channel configurations are currently set on the router?
    Armor, Smart Parental Controls or Circle, IPv6 and Traffic Meter.
    Try enabling SIP ALG under routers web page under Advanced Tab/WAN Setup.
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    • Orbidude's avatar
      Orbidude
      Guide
      FURRYe38, thank you for the info.
      To answer some of your questions.
      I’m using firmware v7.2.6.31_5.0.24
      The house is 3500 sq. ft.
      Modem: Arris - Surfboard S33. The 850 router is connected to the S33 2.5 Gbps Ethernet. I’m using Spectrum as my ISP. My downloads are 1200, uploads 42.
      The main router is upstairs (center of house) and the 2 Sat’s are downstairs about 60-65 feet apart.
      I haven’t had this problem with my wired Mac Studio Ultra.
      I’ll get back regarding channel config’s. My neighbors are not very close.
      Since updating the firmware on the router/sat’s, I haven’t powered off the units. I’ll try that and the modem as well.
      All cables are CAT 6a.
      I’ll try disabling and enable what you suggested.
      I’ll come back when I’ve done these tests.
      Thanks again for all your help. I appreciate it. šŸ˜Š
    • Orbidude's avatar
      Orbidude
      Guide
      FURRYe38, here are my results regarding your questions.
      >>> Armor, IPv6 and Traffic Meter are disabled. I can’t seem to locate Smart Parental Controls or Circle.
      >>> SIP ALG is disabled.
      Thanks!
      • FURRYe38's avatar
        Smart Parental Controls are handled in the Orbi app.
