Dazza762's avatar
Dazza762
Luminary
Jan 12, 2022
Factory reset Orbi system
I want to do a full reset of my RBK753 system. Will erasing the router config in the admin website interface also wipe the attached satellites? The manual doesn't specify. I basically want to set the whole system up from scratch.
  • plemans's avatar
    They'll need to be re-sync'd which will update them with the new settings.
    • Dazza762's avatar
      Dazza762
      Luminary
      But they won't have been wiped along with the router? I'd like to get them all back to out of the box settings.
      • plemans's avatar
        You can always reset them as well if you'd like to ensure they're wiped.
        They've got a reset button.
