NGfalsead's avatar
Jun 30, 2020
False Parental control advertising
NG is clearly involved in false advertising than I intend to be very vocal about. For one they don’t have parental control be competition. Fine they partner with Circle. But for thei higher end device (WiFi 6) then don’t even enable that. Consumer is not informed about that either. Infact so many places they set expectations of parental control being enabled. Please don’t say crappy access control = parental control
Shame. Buyers beware
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi NGfalsead,
    Welcome to NETGEAR Community!
    The Circle Smart Parental Controls feature is slowly being rolled out to the new models. However, we do not have visibility on firmware and feature updates as well as any ETA. We will take note of your feedback and have it forwarded to the team.
    Blanca
    Community Team
  • FURRYe38's avatar
    I dont' see any advertising of Circle on the Orbi AX web site.
    • idontcare67's avatar
      idontcare67
      Tutor
      You should check out this page: https://www.netgear.com/landings/circle/ under 'Supported Routers'.
      It clearly identifies Orbi mesh routers as supporting this functionality. Nothing on this page or the linked page calls out that this is limited to certain Orbi models. The pages are misleading the reader to believe that all Orbi routers are supported,
      This is clearly false advertising, especially without an ETA.
      • FURRYe38's avatar
        Though it says Orbi routers, is also doesn't specify which ones. Though I would agree, they should specify.
        The forum moderator has posted about this. So users will have to wait and be patient.
        Good Luck.
