javiersalasf
Jul 04, 2025Aspirant
Far satellite download speed are low
Hi I'm looking for help to determine if I have to tweak any setting due one my satellite (3rd floor) not providing ISP download speeds, let me explain a little bit but before I will provide the s...
Jul 04, 2025Guru - Experienced User
Concrete and steel will impede wifi signals and performances. Not much you can do if RBS are wireless with this in the mix. Better option if you can get the RBS ethernet connected to the RBR, then speeds would be better.
javiersalasf
Weird because I had the same infrastructure, satellites are in the same position as the previous ISP, nothing has changed in that aspect, just the ISP itself
