javiersalasf
Jul 04, 2025Aspirant
Far satellite download speed are low
Hi I'm looking for help to determine if I have to tweak any setting due one my satellite (3rd floor) not providing ISP download speeds, let me explain a little bit but before I will provide the s...
javiersalasf
I'm doing speedtest by ookla in the app from android and also from windows (when doing it via ethernet)
michaelkenward
Jul 05, 2025Guru - Experienced User
javiersalasf wrote:I'm doing speedtest by ookla in the app from android and also from windows (when doing it via ethernet)
That measures the speed between your Android device and the Internet. It does not measure the speed between the Orbi router and the Internet or the satellites and the Internet.
If you use the Orbi app, you can measure the Internet Speed. That's the speed between the modem and the Internet.
The Orbi app also has a tile for WiFi Analytics. That will check the speed speed of the Wifi connection from the device that your Android device is talking to.
You might like to check those measurements to remove the Ookla app from the variables.
As CrimpOn​ says, a lot depends on how you measure things.
javiersalasf wrote:I'm wondering if maybe is there any setting that I would have to tweak to get an stable 350 mb up/down in all the my network?
That may depend more on the Android devices you are using than the Orbi system.
javiersalasf wrote:The difference is that the old ISP I didn't have access to the PPPoE credentials and I was unable to set Orbi as my main router, hence I had to use 2 routers.
With this new ISP I have access to the PPPoE credentials and I was able to put the ONT as bridge and use my orbi as the main router.
Hard to tell what is going on there. What is that ONT?
Just another user with time on their hands.
