skuhn's avatar
skuhn
Follower
Apr 13, 2022
Firmware downgrade of RBR750 from V4.6.7.13 to 3.x
I updated my firmware on this weekend from a 3.x to 4.x version. This lead to back-haul problems with the satellite. It's working after reboot for a couple of minutes and then starts to blink white until I unplug it. Since nothing else changed in my home this is clearly related to the update.
So I want to downgrade the firmware again. This worked without problems for the satellite, but if I do it on the router it doesn't work. When I try to run the firmware update I get following
Steps I did to make the update:
1) Download the firmware (multiple times and multiple versions 3.x and 4.x to make sure there was nothing bad)
2) Unpack it
3) Upload it
4) Enable the yes button via dev tools
5) Click on yes
6) It fails with the above error
Is there anything I can do to make the downgrade of the router work?
  • FURRYe38's avatar
    First off how did you update FW to v.13? Manually or Auto update? Manually is recommended.
    Did you first update the RBS then RBR?
    Is the RBS wireless or wire connected to the RBR?
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Downgrading to v3 FW is not supported.
