rbrosse2's avatar
rbrosse2
Follower
Dec 04, 2021
firmware version
Hi,
I bought a RBK352 wifi system
My router is on V4.4.0.10_2.10.63  (automaticaly updated at startup)
My Satellite  in is on V4.4.0.10
Why satellite  is not at same version ?
Why does  version V4.4.0.10_2.10.63 is not available on the download center
Brs
Daniel
  • FURRYe38's avatar
    IN this case you can manually udpate the FW by logging into the RBS web page and sending the FW file to the RBS.
    Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
    Thank you
  • FURRYe38's avatar
    Possible the RBS didn't get the FW update from the RBR.
    One can manually download the FW file for the RBS and manually update the RBS to same version:
    https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satellite
    rbrosse2 wrote:
    Hi,
    Brs
    Daniel
