fli's avatar
fli
Follower
Aug 06, 2021
firmware vunnerability
It's unbelievable that the firmware is so vulnerable:
1. admin web login with clear text password without TLS or SSL
2. The CVE-2018-10822 issue
3. No way to stop SSID broadcasting
With this price tag, could you enhence the above?
  • FURRYe38's avatar
    1. admin web login with clear text password without TLS or SSL < Most routers don't need any TLS or SSL on the admin log in from a local side. Been like this for a long time now.
    2. The CVE-2018-10822 issue< This issue is in regards to D-Link effected routers. Not NG.
    3. No way to stop SSID broadcasting< Been like this since Orbi AX released.
  • I could find a non-broadcasted SSID in about 30 seconds on my cell.  That is not security.
    • FURRYe38's avatar
      You have a screen capture of this?
      • Ragar99's avatar
        Ragar99
        Luminary
        I think you misunderstood.  I am not saying Obri allows the user to hide the SSID.  I meant in general it is pretty easy to find hidden or unbroadcasted SSIDs.
