andrewsolo
Jan 21, 2025Aspirant
Frustrated, MOEN Water Shut Off Valve Disconnecting From Orbi RBR750
Hi, My MOEN Smart Water Valve always connects to the RBR750 and then disconnects after 1 hour. I am told by support for the Orbi mesh system make sure to have band steering turned off to have a mo...
andrewsolo
Thank you for trying to help. I think you are asking firmware? In phone app it says v4.6.9.11
Jan 21, 2025Guru - Experienced User
Ok ya, v4 doesn't have separate IoT network support.
Do you have any RBS? if so, are they RBS750 or 350s?
