rickerr63's avatar
rickerr63
Guest Access to Attached Devices
I have a guest network because I have some devices that cant support WPA3.  Any way I can set up to use WPA3 on the main network and WPA2 on the Guest network so that Guest can access wired network devices, such as printer etc?
  • FURRYe38's avatar
    What model Orbi do you have?
    I believe Orbi AC series does not have WPA3 support at all.
    Orbi 3/7/8 series systems have WPA3 support however don't offer mixed WPA2/3 support. We hope in the future NG will support this as the new Orbi 9 series does support mixed WPA2/3 support.
    • rickerr63's avatar
      rickerr63
      Thanks.  I have the RBR750 Mesh Router with 2 satellites (it's not in the dropdown list on this forum for some reason).  All work perfectly with WPA3 enabled and I have WPA2 on the guest network to allow some devices that dont support WPA3 to connect.   I wanted to give the guests access to my printer for example which is hard wired to the main router.  I also want them to be able to see NAS drives on the loca network.
      I could go back to WPA2 on the main network so that all can connect but wanted to use WPA3 if I can for increased security.
      There was some discussion about options to allow guest to see each other and access LAN devices but I cant see those options in my Guest Network setup.
      Cheers,
