iwoodchuck
Apr 12, 2023Follower
Guest Network DNS
What DNS server does guest network use when enabled? I have my normal one using certain ones that control traffic to certain sites, but the guest network seems to allow when turned on and does not show up in the logs. Is there a way to change the guest network DNS?
Typically Guest Network devices get DNS from the router so it would be the routers IP address used for DNS.
Guest Network DNS is not user configurable.
1 Reply
