wagnermba
Jun 26, 2022Guide
Guest Password on RBR750 Orbi Doesn't Work
Hi: I set a guest password for my RBR50 Orbi Router -- using Orbi app on iPhone and also from the web admin page. But, whenever I try to login to it via phone or computer, it says "incorrect passwor...
- Jun 26, 2022
What devices do you have connected?
What special characters are you using?
As a test, does Password123 work if you set this using the RBRs web page?
Jun 26, 2022Guru - Experienced User
- wagnermbaJun 26, 2022Guide
Thank you. By removing special characters (exclamation marks) it works great. Thanks!
- FURRYe38Jun 26, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
