wagnermba
Jun 26, 2022Guide
Guest Password on RBR750 Orbi Doesn't Work
Hi: I set a guest password for my RBR50 Orbi Router -- using Orbi app on iPhone and also from the web admin page. But, whenever I try to login to it via phone or computer, it says "incorrect passwor...
- Jun 26, 2022
What devices do you have connected?
What special characters are you using?
As a test, does Password123 work if you set this using the RBRs web page?
wagnermba
Jun 26, 2022Guide
Thank you. By removing special characters (exclamation marks) it works great. Thanks!
Jun 26, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
