ARugg
Jul 28, 2020Tutor
hard wire PS4 recs
I am using a cable modem, CM1100, and the Orbi AX4200 system. Cable at 500Mbps. I have no issues running three apple TVs, three Ipads, a MacBook, and three phones, I am satisfied with their performance. I want to hard wire my PS4 (for online GT Sport), as the Wifi has not been as stable as I need it to be, I came close to losing a sure win race once, and I don't want to risk it again. Wireless, the PS4 is seeing 70Mbps, but during game play, I have had one red bar. Before I run cable and and install jacks, I would very much appreciate recommendations on the preferred configuration. Appologies if this has been discussed prior, I have done several searches and none match my particular situation.
Thanks in advance!
You can ethernet connect the PS console to the RBR for best performances. If you have run out of free LAN ports in back, you can install a external Gb switch, such as NG GS108 to help add LAN ports to the back of the RBR.
