dcsaul
Oct 14, 2021Aspirant
Harmony Hub Not Attaching to New Orbi RBR853
Hi. Just bought an Orbi AX6000 RBR853+2 satellites, to replace my Linksys Velop. Everything has connected to the new network, EXCEPT my Harmony Hub. The hub connected to the Velop fine, but it will not connect/pair with the Orbi.
I have tried:
1. turning it off/on
2. pressing the reset button and trying all 3 reset options
3. changing to a more powerful power cord
4. the manual connection option using bluetooth
5. etc.... everything ever posted on the web for this problem.
I cannot see it on my network, so it does no good to try the scan all IP addresses.
On my Orbi I just have the one primary network setup: no guest, IoT, etc.
Does ANYONE have an actual answer for this? Thanks very much!
SOLUTION: I did a factory reset on the hub and remote. The process went smoothly!
- quagmire1Luminary
You've posted to the wrong forum. This forum is for Orbi Pro users, and is not very active.
The forum you want to post to is:
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/bd-p/en-home-orbi-ax
Try disabling AX mode on the RBR under Basic Tab/Wireless settings and set CTS to 2347 Under Advanced Tab/Advanced Settings/Wireless Settings
I have tried:
