jonmell
Jul 01, 2025Guide
Have to constantly forget and rejoin network
Hi - I have an Orbi 6 RBR850 and two RBS850 satellites. All was working fine until I moved home (kept the same SSID / Password etc.). Now whenever I move a device in the house and it needs to switch ...
- Jul 05, 2025
jonmell wrote:
It's Virgin Media's hub 4 - brought the same modem with us when we moved
Running in bridge (modem only) mode?
Did you reset and reconfigure everything when you moved?
Just another user with time on their hands.
Jul 01, 2025Guru - Experienced User
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/kb/en-orbi-knowledge-sharing/netgear-mobile-applications-and-androidapplewindows-devices-faq/2457046
- jonmellJul 05, 2025Guide
Thanks. Firmware is V7.2.7.15.
~2,500 Sq ft
They're more than 30ft apart and wired
We do use Private Relay on iCloud so will switch that off and see if it helps
- michaelkenwardJul 05, 2025Guru - Experienced User
I left everything exactly as is. I could never get official modem mode working (even in the old place) so I just leave it in regular mode, switch WiFi off, plug into the Orbi and it works fine. The only change is the satellites are now wired, not wireless so have unplugged and we’ll see if this helps
- FURRYe38Jul 09, 2025Guru - Experienced User
For that size of home, the RBR and just one RBS would be needed. Not two. https://youtu.be/UR0viMLISz4
Try turning OFF one RBS for now.
Has disabling Wifi Private IP address OFF helped any? NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
~2,500 Sq ft
