jonmell
Jul 01, 2025Guide
Have to constantly forget and rejoin network
Hi - I have an Orbi 6 RBR850 and two RBS850 satellites. All was working fine until I moved home (kept the same SSID / Password etc.). Now whenever I move a device in the house and it needs to switch ...
- Jul 05, 2025
jonmell wrote:
It's Virgin Media's hub 4 - brought the same modem with us when we moved
Running in bridge (modem only) mode?
Did you reset and reconfigure everything when you moved?
Just another user with time on their hands.
CrimpOn
Jul 01, 2025Guru - Experienced User
When a network "acts differently", it is often useful to know what changed?
- It is the same Orbi router and two satellites.
- The WiFi SSID/password remain the same.
- Is it the same ISP?
- Was a new setup performed, or were the router and satellites just "plugged in".
- Has the Orbi firmware been updated?
- Are any other devices behaving differently?
