jonmell
Jul 01, 2025Guide
Have to constantly forget and rejoin network
Hi - I have an Orbi 6 RBR850 and two RBS850 satellites. All was working fine until I moved home (kept the same SSID / Password etc.). Now whenever I move a device in the house and it needs to switch ...
- Jul 05, 2025
jonmell wrote:
It's Virgin Media's hub 4 - brought the same modem with us when we moved
Running in bridge (modem only) mode?
Did you reset and reconfigure everything when you moved?
Just another user with time on their hands.
jonmell
Jul 05, 2025Guide
Thanks. Firmware is V7.2.7.15.
~2,500 Sq ft
They're more than 30ft apart and wired
We do use Private Relay on iCloud so will switch that off and see if it helps
michaelkenward
Jul 05, 2025Guru - Experienced User
jonmell wrote:It's Virgin Media's hub 4 - brought the same modem with us when we moved
