jonmell
Jul 01, 2025Guide
Have to constantly forget and rejoin network
Hi - I have an Orbi 6 RBR850 and two RBS850 satellites. All was working fine until I moved home (kept the same SSID / Password etc.). Now whenever I move a device in the house and it needs to switch ...
- Jul 05, 2025
jonmell wrote:
It's Virgin Media's hub 4 - brought the same modem with us when we moved
Running in bridge (modem only) mode?
Did you reset and reconfigure everything when you moved?
Just another user with time on their hands.
jonmell
Jul 05, 2025Guide
Everything the same except I wired the satellites as the house has ethernet cabling. I'll try as wireless and see if that helps.
michaelkenward
Jul 05, 2025Guru - Experienced User
Yes, but did you reset and setup the network to work with the new location?
CrimpOn wrote:Was a new setup performed, or were the router and satellites just "plugged in".
That is an important question. If you haven't done that already, reset and reconfigure the network and then change the SSID / Password to your preferred settings.
jonmell wrote:I'll try as wireless and see if that helps.
Wired should be better.
