jonmell
Jul 01, 2025Guide
Have to constantly forget and rejoin network
Hi - I have an Orbi 6 RBR850 and two RBS850 satellites. All was working fine until I moved home (kept the same SSID / Password etc.). Now whenever I move a device in the house and it needs to switch ...
- Jul 05, 2025
jonmell wrote:
It's Virgin Media's hub 4 - brought the same modem with us when we moved
Running in bridge (modem only) mode?
Did you reset and reconfigure everything when you moved?
Just another user with time on their hands.
jonmell
Jul 19, 2025Guide
Reset everything and switched to modem mode seems to have worked! Thanks all
- FURRYe38Jul 19, 2025Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
