paulr0001
Mar 12, 2022Tutor
Help for a rookie on AX4200 RBK752
My new Orbi AX4200 RBK752 keeps losing connection to some devices, and now if i enter its IP address into a browser it just give me password reset, but no access to the router. My Sonos speakers hav...
Mar 12, 2022Guru - Experienced User
A few more details are needed.
1. what modem/gateway is the router connected to?
2. what firmware is on the router and on the satellites?
3. do wired devices drop or just wireless?
4. does it say connected no internet or what actual error do you get?
5. did you try a factory reset?
- paulr0001Mar 12, 2022Tutor
1. what modem/gateway is the router connected to? its connected to a Plusnet Hub One
2. what firmware is on the router and on the satellites? its as it came out of the box ten days ago. I tried twice to update the firmware using the app, but it failed. router is V4.6.5.14. the satellite doesn't show any firmware on the app. just a -
3. do wired devices drop or just wireless? wireless only i think. the only wired device is my Mac and that's been fine.
4. does it say connected no internet or what actual error do you get? no errors on the Orbi. the sky tv says its lost internet connection. The Sonos speakers were ok, then lost one (out of the five i have). When i reconnected the one, it disconnected the other four.
5. did you try a factory reset? No not yet.
- plemansMar 12, 2022Guru - Experienced User
2 things.
First is that plusnet hub one is a modem/router combo device. It causes a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Modethe other is that if your orbi is only 10 days old, you have 90 days of free support from netgear. If your not very technilogically inclined, it might be easier for you to set it up over the phone. Once you get it setup, make a backup in case you ever need to reset. And even writing down might help since support is only free for 90 days from purchase (on new devices).
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.
