hewire44
Mar 02, 2023Follower
Help Orbi 753 system problems
Just bought the Orbi 753 system, I have a modern/router from my ISP. Connected via webpage and changed to AP mode which worked ok but unable to add satellites, they were just showing purple lights despite being within 3 feet of the router. Tried everything. Finally reset everything by holding in the reset button and now cannot connect at all to any of it. The satellites are showing blue lites after a reset. Can nether connect via app or via laptop onto orbi login.com
What am I missing?
1 Reply
Usually if the led's on the satellites are blue it means they linked.
What do the LEDs on my Orbi router and satellite mean? | Answer | NETGEAR Support
Did you try hardwiring the satellites into the router and syncing them for a period?
