tburba56's avatar
May 24, 2023
Hidden Port Forwarding values RBR760
I changed ISPs to AT&T Fiber. I didn't want to use their equipment as I needed to continue with my Orbi760 with a number of static IP addresses. We did an IP Passthrough from the AT&T modem/router to the MAC address of the Orbi.  It kinda worked. So we reset the IP Passthrough again. The Orbi came up with an error indicating it had changed my network from 192.168.173.1 to 10.0.0.1 due to a conflict. Sigh
I went through the hassle of changing all my static addresses to the corresponding 10.0.0.xxx addresses. When I got to the port forwarding, none of the older forwards were listed. I tried to set them to corresponding TCP/UDP forwards to the new addresses and Orbi manager indicated I had a forward already to that Port... obviously to the 192.168.174.xxx
However, I can't see them to be able to delete them. Is there any way to clear all the port forwards without having to do a Factory reset and reload all my configurations again?
  • Thanks for spelling it all out for others that may read this later. Your answer is much more straightforward and complete.
    I already had it set up with the IP Passthrough. I messed up by not clearing the routing table on the AT&T device by doing a reboot of it with the Orbi disconnected. I should have let the tech do the IP Passthrough AFTER rebooting the AT& T device.  The table would have been clean and not forced the 192.168.173.xxx to be reset to 10.0.0.xxx. That's all done now and seems everything is back working again.
    I appreciate your insight. Thanks again.
  • FURRYe38's avatar
    Not sure why the Orbi would have changed to 10.x pool range. Default IP pool range for NG routers is 192.168.1.1 not 192.168.173.x. Unless it's incorrectly detecting 192.168.1xx.x
    .1.1 should work on Orbi. What happens if you manually change back to 192.168.1.1 on the RBR?
    • tburba56's avatar
      tburba56
      Tutor
      Actually, it turned out to be the AT&T Modem/Router. Once connected to the Orbi, any settings regarding Port forwarding remained in the AT&T device routing table. No wonder I couldn't see them. Once I rebooted the AT&T device, then I could set the port forwards as I needed. Most everything is working. I still have an issue with my Channels DVR and port 8089 when I am away from my house. But I was able to set it. Before I got errors it was already set.  I'll have to dink around with that on something other than my cell. I may not have enough bandwidth on my mobile to run TV over cellular. May have to be wifi only.
      Thanks for responding
