jc1742
Nov 29, 2022Aspirant
How can I get our Orbi RBK75 to send messages via its Ethernet ports?
We have some Ethernet-only gadgets, which worked with our old Apple Airport router (plus an old, Netgear Ethernet router), but don't work with our new Orbi RBK75 (with or without the Ethernet router)...
Nov 29, 2022Guru - Experienced User
What are these Ethernet Gadgets that you have?
Have you tried contacting the Mfr for these gagets to see if they have any help and support information regarding getting them conencted?
For additional LAN ports one can always add a GB ethernet switch to the back of the RBR for additonal ports if needed. They come in 5, 8, 16, 24 and higher combinations. I recommend NGs GS 105/108 series thats unmanaged.
CAT6 lan cable is recommended.
jc1742 wrote:
We have some Ethernet-only gadgets, which worked with our old Apple Airport router (plus an old, Netgear Ethernet router), but don't work with our new Orbi RBK75 (with or without the Ethernet router). I'm guessing that something's not configured right. We've only had the Orbi for a few days, and it only got configured to do wifi this morning, so we don't know the Netgear terminology very well yet. Is there any documentation on how to configure this? Does anyone have suggestions for things to try?
(I did try several different CAT cables, and none of them worked, though they all work with some other gadgets we have. Part of the reason we went with this model is its 3 extra Ethernet ports, which we thought were there for what we're trying to do.)
