javiersalasf's avatar
javiersalasf
How can I tie my device to connect to specific satellite?
Hi all,
I have a playstation 5 and is 5 ft away from the nearest satellite, when I turn it on, it always connect to the router that is far away (around 26-29 ft away) instead of the nearest satellite, is there something that I could do to tie this device to that specific satellite?
I'm currently running the latest FW in RBR750 V7.2.7.15_5.1.16 and satellites are in the same version.
Just for additional information, I have reduced the 5Ghz signal from 100% to 50% to have more chances to connect to the nearest satellite, which is not doing it.
  • CrimpOn's avatar
    CrimpOn
    Over the years, "where devices connect" has been one of the most common topics on the Community Forum.  There seem to be systems from other vendors that include a feature to force WiFi connections by device.  Netgear Orbi has never had a similar feature.  There appear to be two strategies users employ:
    1. Restart "dumb" WiFi devices after the Orbi system is completely active.  Devices intended to be mobile appear to be programmed to continue looking constantly for a "better connection".  (This is the basis of roaming.)  Devices that are expected to remain in one location (smart plugs, televisions, speakers, light bulbs, garage door openers, etc.) appear to be programmed to find a good connection and then stop looking.  When the Orbi system starts up, the router begins broadcasting WiFi signals before the satellites.  Some users have found that powering a device down and back up seems to get it to switch from the router to a nearby satellite.  Pain in the (you know where).
    2. Reduce Transmit Power so that WiFi nodes that are farther away appear to be much less desirable. (and, stop and restart WiFi on the device after making the change.)  This approach is a double edged sword because lowering Transmit Power can drastically reduce the total area with good WiFi coverage.
    • CrimpOn's avatar
      CrimpOn
      p.s. unless there is a wall in that five foot distance, I would switch to an Ethernet connection in a heart beat.
    • plemans's avatar
      Plus, you have to consider that when gaming, each "hop" adds latency. And gaming doesn't take that much bandwidth. So, the PS5's roaming protocol could be saying, "The router is close enough and has plenty of bandwidth at a lower latency." Let's connect to that.
      But CrimpOn has a great point, if you have a hardwired option that's only 5 ft away, I wouldn't be on wireless
  • FURRYe38's avatar
    What is the size of the home in SQ Feet?
    What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
    javiersalasf wrote:
    Hi all,
    • javiersalasf's avatar
      javiersalasf
      House is 1600 sq ft, nearest satellite is 6 ft at max, router is at 26 to 29 ft away from the PS5, I have changed again signal from 50% to 100% and seems is working better, I see it connects more ofter to satellite, but sometimes it connects to router
      • FURRYe38's avatar
        Can you get the RBS a bit farther away from the RBR.
        Also try 25% as well.
