CrimpOn
Feb 05, 2020Guru - Experienced User
How Capture WAN Traffic?
A trivia question: Does the AX model have a "debug" page with the option to Capture LAN/WAN traffic? What are the storage options? With my (ancient) original Orbi RBR50, I have plugged in a 32GB USB drive and captured an entire day (24 hours) of LAN/WAN traffic for analysis. (I looked in the User Manual, but of course "debug" features are not in it.)
You are correct. Only system memory which will out put to a .zip file on your PC when you go to collect it.
Same thing on Orbi AX.
I thought the AX model has no USB port? Is the only option to save to System Memory? My guess is that this limits the capture to 200mb or so?
