gtbecksr
May 03, 2024Aspirant
How do I disable "Node Jumping" on an Orbit Tri-band WiFi 6 System
I have an Acurite Atlas direct to WiFi Weather system and it keep dropping the connection after about 30 minutes. Their support personnel advised me to disable Node Jumping and I can't find anything about it or how to do it.
Something that is not a user changeable feature on Orbi systems. Roaming or jumping is all done at the client device level. Something that Orbi systems don't have any control over.
What model Orbi system do you have?
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰Does this happen with the RBS turned OFF?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.- gtbecksrAspirant
My Orbi router is Model RBR750. By RBS are you referring to the satellites? If so I have one router and two satellites. There is about 30 between the devices. They are connected wirelessly. My home is about 3000 Sqft.
I have not tried to turn off any satellites. I will try and see if that helps. The firmware version on my router is V4.6.14.3_2.3.12. The modem is from Spectrum Cable, It is labeled with their name so I don't know who the manufacturer is. It looks like the model number may be ES225i . The Orbi router is connected to the modem via the ethernet cable that was provided with the Orbi bundle.
Ok, Let us know if the device keeps connected with just the RBR. If So, turn on ONE RBS and try again.
Something else you can do to see if you can steer the device to a particular signal, turn down the transmit power on the RBR from 100% to say 50% or 25%. See if this helps keep the device connected to it's closest signal source. Under Advanced Tab/Advanced Settings/Wireless Settings
After checking all this, you might update FW on the system at some later point:
You may have a HITRON branded modem.
