KRBMT
May 07, 2023Aspirant
How do I distinguish the 2.4GHZ on ORBI RBR750 firmware V4.6.9.11_2.3.5
Hello. Does anyone have CURRENT info/scripts that will allow me to separate/distinguish the 2.4GHZ from the 5GHZ on the ORBI RBR750 router? I am trying to connect Defender cameras, which require th...
May 08, 2023Guru - Experienced User
So you might want to also change the power output of the 5Ghz radio to 25%. Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was. Turn OFF all RBS temporarily as well.
Be sure that 20/40 MHz Coexistence enabled.
Separation of SSIDs is NOT supported on Orbi systems.
- KRBMTMay 08, 2023Aspirant
Any chance you could tell me what the exact option in the NetGear software is, to decrease the power output? I hope that is not done via my ISP, because they won't work with me due to the fact that I am no longer using their router, but the Orbi.
And, once I unplug the satellites and move my phone away from the router, how to I tell if it got hooked up to the 2.4ghz?
Thanks you guys for trying to help a newbie 🙂
- FURRYe38May 08, 2023Guru - Experienced User
Set the 5Ghz power from 100% to 25%. Under Advanced Tab/Advanced Settings/Wireless Settings
I am going to try a connection directly with the ethernet cable, per the Defender CS. But they say the cameras will fail if the network switches the connection to a 5ghz. I believe, though, that my satellite will ALWAYS be 2.4ghz.
Can anyone confirm? These cameras are to be a long way from the router, out in horse stalls, and I believe they can only connect to my 2nd satellite, where I have router, then XX feet to first satellite, then XX feet to 2nd satellite.
