KRBMT
May 07, 2023Aspirant
How do I distinguish the 2.4GHZ on ORBI RBR750 firmware V4.6.9.11_2.3.5
Hello. Does anyone have CURRENT info/scripts that will allow me to separate/distinguish the 2.4GHZ from the 5GHZ on the ORBI RBR750 router? I am trying to connect Defender cameras, which require th...
CrimpOn
May 08, 2023Guru - Experienced User
Thanks for the links. An interesting connection method. On page 9 of the printed instructions,
https://cdn.shopify.com/s/files/1/0115/0110/9314/files/IP4MCB1-UserManual-v2_WEB.pdf?v=1605717085
it is clear that their "WiFi Range Test" is intended to verify 2.4G signal strength at the proposed camera location. (This step is absent from the setup video.)
Step 6 on page 10 may hold the key. Can you open a QR Code scanner app and display what the information the QR code contains? (I have three different QR code scanners on my Android phone. All work about the same. Point at code. Read results.)
My suspicion is that the camera temporarily creates a WiFi hot spot and the smartphone app reads the SSID to look for from the QR code.
Another tactic that people have found to work in these situations is to turn off their home WiFi system and temporarily substitute a 2.4G WiFi channel with exactly the same WiFi credentials (SSID/password) as their home system. Some people have the old router that the Orbi replaced sitting in a box somewhere. [I have three previous routers.] My smartphone can create a WiFi Hot Spot that happens to be on 2.4G. I create a Hot Spot with credentials that match the Orbi and use a second smart device (tablet, usually. Sometimes an old phone.) to do the setup. After the IoT device is working correctly, power everything off, restart the home WiFi system, and "voila" all is good.)
KRBMT
May 11, 2023Aspirant
Thanks for all the info, but I have run out of time 😞
I did try lowering the percentage/power, as had been suggested, to try to access the 2.4 ghz. But still couldn't access it.
Yes, the Defender setup does create a temporary hotspot upon reading the QR code; I believe they are same across my 2 cameras. But my network didn't appear; couldn't enter its password.
For now, I went back to my router from my ISP ( A GigaSpire), and named the two networks differently for 5/2.4, with same password. Trying 2 different non-Netgear extenders, one set to be explicitly only 2.4ghz that both my phone and camera can connect to - they don't have the range of the Orbi satellites but I might be forced to this method.
Not sure I could complete setup like this and then go back to Orbis, as you suggest, but will try again after I return.
While the Defender setup is clearly 'deficient' in not being able to pick out the 2.4ghz from the Orbi router (my Arlo setup had no problem), their cameras can handle temperatures down to -40F, so that is why I chose them.
Did NOT realize compatibility was going to be such a challenge!
I am not happy with Netgear not separating the channels, but I AM impressed with the Netgear community 🙂
- CrimpOnMay 11, 2023Guru - Experienced User
KRBMT wrote:
Yes, the Defender setup does create a temporary hotspot upon reading the QR code; I believe they are same across my 2 cameras. But my network didn't appear; couldn't enter its password.🙂
Can you share the contents of the QR codes?
My sense is that like most Internet of Things (IoT) devices that do not have a keyboard to enter parameters with, the camera creates a WiFi access point, the smartphone app connects to it, and communicates the home WiFi credentials (SSID/password) for the camera to search for.
Typical IoT devices name their temporary access points with some obvious name, such as "MYBRAND-123456". The smartphone app goes through the list of available access points searching for one that it recognizes, "Hey. This WiFi is named just like our smart plugs!" The smartphone app connects to that unique SSID and communicates the home WiFi SSID/password.
Cameras have the advantage of being able to take pictures. Almost every camera I have tried uses the smartphone app to create a QR code with the SSID/password and the camera reads this information from the QR code. This Defender camera is the first one I have seen where the smartphone app reads the QR code instead of creating one.
- FURRYe38May 12, 2023Guru - Experienced User
So when you get back, try setting up your current ISP routers 2.4Ghz SSID name and PW and Security Mode and channels, to same as what you have on the Orbi. If you have the cameras connected on the ISP router, then all it should take is that turning ON the Orbi RBR and letting it come to ready, once it's ready, turn OFF the wifi radios on the ISP router. The cameras should auto migrate over to the Orbi RBR seemlessly and connect there with out having to do anything else.
