tinhnghia
Feb 23, 2024Aspirant
how set up orbi rbk763 connect direct to nbn FTTC TPC provider
Hi. I am with TPG using NBN FTTC. The provider supplied NBN box with modem TP LINK ARCHER 1600. I would like to connect my new mesh wifi orbi rbk763 direct to NBN box without using TP LINK ARHER1600 but dont know it work or not. Please help
Can you please look on the product label for the exact model number of the Archer?
What does the ISP say about not using the Archer?
This document appears to indicate that the Orbi router would be a direct substitute for the TP-Link router that was delivered:
https://www.tpg.com.au/sites/default/files/doc/NBN_TPG_A5.pdf
Does your installation have an NBN Connection Box similar to the one in that document?
- tinhnghiaAspirantAttached the set up nbn ftrc guide provided by Tpg
https://community.tpg.com.au/t5/Broadband-Internet/NBN-Fibre-to-the-Curb-FTTC-Setup-Guide/td-p/101369
- tinhnghiaAspirantModel is TP-Link VR1600v
