oulyve
Sep 29, 2025Aspirant
How to connect my RBR850 to my KPN network (NL)?
Dear community, I am located in The Netherlands. I was so far an happy owner of an RBR850 mesh system ( 1 main device and 2 satallites) for more than 3 years. My internet provider was ODIDO but I ...
CrimpOn
Sep 29, 2025Guru - Experienced User
The first step is to connect the RBR850 WAN port to the KPN device. This should provide an internet connection.
Yes, there is a possibility that the KPN device is a 'router' (rather than simply a modem or Fiber Optical Network Terminator[ONT]). If so, this would cause a "Double NAT" situation (internet search for more details), but that will affect specific applications.
It might be a good idea to do a Factory Reset on the RBR850 router before connecting.
